Hi Everyone,
Today's question is regarding what happens when you run a machine into the limit switches.
I have been trying to reverse the axis direction of one of my slide motors for the past few days and this has resulted in several cases where the limit switches get tripped. The settings I have are to allow driving out of the switches, but it seems that once they are tripped, the current level or something drops and the machine won't move.
I have even physically removed the switches so they are no longer active, but still no motion. Then I shut off Kmotion and the machine and restart, but still nothing. The initialization program won't even complete. So I unbolt the servos, stand them on their ends on the machine bed and the initialization program works fine. I bolt them back up and everything is normal.
So I got to wondering, is there some kind of power limiter that triggers once the switches are hit? It's almost like the servos don't have enough power, once they've tripped the limits, to turn the drive screws. However I can easily turn the screws by hand with the motors removed.
Any thoughts?
David.
